I have had this car since 1990, done all the basic upgrades and then some. I installed Razors alky kit a few years back along with a chip from Eric i believe. The problem occured last year while doing a few laps for charity at Texas motor speedway, i would drop back as far as they would let me then run it up to about 135 before having to shut down due to running up on the cars in front. It was running about 17 pounds on the turbo with no knock according to the scan master. Coming off the track the car seemed to be running real rich. We had to park and wait a little while before we could leave, It took a lot longer turning over to fie off but did start and ran decent the 50 miles home. I parked it in the garage and forgot about it for a while. I went out to start it and the fuel pump will not shut off and then i noticed fuel coming out the turbo elbow where the flapper that controls the puck is. Not having a clue i sent the accufab fuel presssure regulator rebuilt since it was probably 10 plus years old. Re installed it and still the fuel pump continues to run. I have not tried to start it due to the fuel running out the turbo elbow. I decided to pick up a fuel pump relay to see if that would shut the pump off after a few secnds. It did not. I have a guage on the fuel rail and it shows it is building and holding 40psi. The car has 125k on it, i bought it about 1990 with 40k on it and over the years did all the basic upgrades myself. Walbro fuel pump, hot wire, green stripe injectors, kenne bell air intake, valve covers, bigger oil filter, razor alky kit, bigger intercooler elbow ( brand escapes me for the moment) ported doghouse from some forum member that was always in the doghouse years ago ( maybe his name was Kieth?), valve springs, scanmaster, boost guage, ported elbow, bigger downpipe, some trans work by kenne bell along with a different transpan and some other stuff i am forgetting. So what did i do to my wifes car. ( she claims it is hers)
