May 23, 2007 #1 D dvernst Well-Known Member Joined Jan 9, 2006 Messages 1,879 What's the best fuel pump for low 11's to high 10's? Thanks
May 23, 2007 #2 3 3.8TransAM Member Joined Apr 8, 2004 Messages 325 Walbro 255 should suit you well. Run it with a hotwire kit if u lose more than .1-.3 from battery to the rear of the car. later Jeremy
May 23, 2007 #3 D dvernst Well-Known Member Joined Jan 9, 2006 Messages 1,879 That's better then the 340?
May 23, 2007 #4 S SouthernCal GN I come in peace....AK AK Joined Mar 18, 2004 Messages 2,561 The Walbro 307 and 340 are both rated at 255lph; the 340 has a higher pressure rating. Info for you: http://www.turbobuick.com/forums/general-turbo-buick-tech/33927-walbro-307-vs-340-a.html HTH!
May 23, 2007 #5 Q Quiky One Active Member Joined Dec 31, 2005 Messages 8,079 Get the 340 and hotwire kit from Racetronix and call it done. Jason
May 23, 2007 #6 S Sweet6 Well-Known Member Joined Jun 12, 2001 Messages 3,535 yes, the kit from racetronix is nice. I thougt I heard they make a new pump now? and the 340 is not made anymore? But the 340 is a good pump for your goals.
May 23, 2007 #7 Q Quiky One Active Member Joined Dec 31, 2005 Messages 8,079 Sweet6 said: yes, the kit from racetronix is nice. I thougt I heard they make a new pump now? and the 340 is not made anymore? But the 340 is a good pump for your goals. Click to expand... It is a 340 with a few little mods...same flow I do believe. Jason
May 23, 2007 #8 S Sweet6 Well-Known Member Joined Jun 12, 2001 Messages 3,535 I remember reading something about the change but forgot what it said.
