Tony sy2356
- Jun 26, 2001
Just curious if a check valve is absolutely needed in an aftermarket fuel system.
Does the pump get to pressure quickly enough on startup that they aren't required? Or will it cause a really annoying long crank condition if i skip the check valve?
I'm running an A1000 pump from a sump in my stock fuel tank if it makes a difference.
Any opinions would be welcome
TIA
Tony
TIA
Tony
