all right, i have started to do a motor swap, going to be a 434 inch small block with probably a 91mm turbo or so. need to sell all this v6 stuff.
motor is COMPLETELY dissasembled for a rebuild, nothing has been machined yet, cylinders were honed to 3.803-3.8035 (0.003 over)and cleaned up good enough for stock size pistons if wanted. rods and crank have had casting ridges removed, oiling mods in block. everything is off my car, 130k miles and factory original, even the valvesprings. would like to sell as a complete package, or at least make just one delivery to a couple guys or something. will deliver as far as Minneapolis, Souix falls, grand forks, duluth area.
Complete 87 engine, dissasembled, includes everything listed except headers, turbo, turbo oil feed/return, cam and timing set. 3-bar map sensor goes with alky kit if sold seperatly.
all sensors
full engine compartment harness
ECM
adj. fuel press reg
36# Bluetops
RJC Power Plate for stock plenum
commander chip for 36#
includes all accesories, starter
fresh refab'd radiator and fan
stock intercooler
AlkyControl progressive meth kit
BRF 2004R, original, orange stripe (3000 stall), new converter, trans needs rebuilt for performance use/ stator support is worn
This is basically everything needed for a hybrid or any swap. I want to keep it together as much as possible. i will let this ad run for a week or 2 and if nobody wants it all together i will seperate motor and tranny, maybe alky kit. I want $2800 for all of it, that includes delivery to above places. if you think thats unreasonable pm me a offer and i may consider it after a while, and no lowballing, bs'in, if you want it you know damn well what its worth so be honest. i will answer any questions day to day. thanks.
Gary
all sensors
ECM
adj. fuel press reg
36# Bluetops
stock intercooler
Gary
