fuse panel?
87gnstock
Bigger isn't better!
I am trying to wire some gauges and i need to find the fuse panel on a 87 gn.
Take the plastic panel out from under the driver's side of the dash and the fuse box is in the upper left hand corner. If you are going to tap into a fuse, go to the parts store and get the spade clips that go around the fuse and allow you to plug the wire on the end. Don't just shove the wire into the fuse.
