S
stevec
Guest
Just wondering what you guys are running for rear gears and tire size??
My combo is a 3.23 with 2755015 drag radials(25"). I have been shifting the motor 274 Stage II at 6800 and going through the traps at ~7000 with the conv locked up mph is 142.
I believe my engine combo will max out at around 7500 with 236/236 cam and 30 psi boost. Should put the MPH around 146. The conv is 4200 stall.
The reason is were are going to a 9" ford and may try more gear and taller tire.
SteveC
SteveC
