gear
Lee Thompson
Looking for a 32 tooth speedo gear. The small plastic one in the trans that goes to the speedo cable. I have an ATC catalog but not listed. Maybe not available at all. What say you experts? Need it before Friday. Thanks
A 32-tooth gear does not exist. Closest you'll get is a 31-tooth gear. We've got them here :)
Greg can you set me up with a speedo setup for a Turbo 400, 3.42 rear and 28" tall tires?
THanks Otto
A combination that'll work for your application would be a 15-tooth drive gear and a 37-tooth driven gear. They're both in stock here.
Great will give you a call soon, Or are you going to the Nats? If so could you bring them?:D
thanks
Thanks Greg, changing both gears is an option I had not thought of. I am wanting to fool my vss sensor for my WOT 3rd gear TCC lockup. Changing just the speedo gear is much simplier. I was wanting to make adjustments at the track.
I have vacation set aside so it all depends on me getting my GN reassembled at this point. The heads, intake and timing cover are all off at the moment. I'll be installing a Comp roller cam so there's a few more things to check along the way.
