Gen 2 Translator adapter
Turbo6Smackdown
Ok, for those of you that run Casper's gen 2 translator adapter harness, where do you mount your translator now? It doesn't seem like there's a lot of extra cable there to pick your spot. And, can you put your pcm back in the stock kick panel with this harness?
Keep mine in the glove box. If you want to do any tweaking, it's easy to reach.
I use the Casper's harness for the MAFT Pro. I put the ECM in the stock location, MAFT in the glove box. Left the top off the plastic interior holder for the ECM. I put the cover back on the underside of the dash, not a perfect fit, but looks OK. I would like to hear what others may have done as the plug and play harness is a little bulky for squeezing in.
I've got Caspers "Plug N Play" harness installed & have the ECM / kick panel cover installed too. It doesn't fit 100% , but it looks OK.
Don't think anyone but me would notice it! LOL
Yup, it'll fit easily in your glove box using just Caspers' Plug N Play harness made for the Gen II.
