Chatmanboy
- Jun 25, 2009
First it was oil, knock, now rpms. AGAIN...
Ive being having trouble with the rpm. it (red lines) on the dash tach and runs like it is. Some say the dash tach is incorrect which i believe also because my scanmaster and after market tach reads different and the same as each other. At first i was having this problem just drive (D) when i hit about 60 it red lines so i put it in (OD) on the freeway. I adjusted the TV cable but didnt do anything. But its still drive good until i reached 60 mph.
So i send a turbo to get upgraded to a TA33 and while it was off i plugged the coolant lines. i get the upgraded back apply it and now on the tach it reads high rpm and it seem as if its slipping in 1/2nd gear and not boosting right. and i go wide open throttle and it hesitate and it red lines and i only get 7-10 pounds of boost.
The scan and aftermarket tach read 2/3000 rpm yet the dash tach reads 6000 and the car runs hard like it is. Can this be a transmission problem? or what!?
Codes flashing is 23 and 15. 23 is cuz MAT not hooked and 15 is coolant low which came up when i changed the thermostat to 160 so im switching it back to stock.
Sorry about the long post, but this car is giving me a headache w/all the money im putting into it.
