Over the years I have been collecting the pieces for a 109 motor and I thought I would post it locally. It has a RJC girdle, steel stock stroke crank, new Scat steel rods, new Wiseco 3.820" (9:1) pistons, SFI flexplate, internal balance, new Pro Gear timing chain and gears, front cover and new oil pump and a new roller cam. I also have M&A heads with roller rockers and ARP studs (ARP used throughtout the motor) and valve covers. I still need to do some machining and balancing but if someone is need of a 9 sec. engine it will be available next month.
$3800 for the short block, $5500 long block.
Jeff
Jeff
