Short block includes all four stock caps that were machined for the girdle. Clean bill of health from the machine shop. Needs reassembly.
109 turbo block
2 dot turbo rods with JE .060 forged pistons and ARP 2000 rod bolts
ARP main studs
standard/standard rolled fillet crank
rjc girdle
rjc crank scraper
20 bolt oil pan
Oil pickup extension
modified crossover pipe for girdle with passenger exhaust manifold
$1,500.00
210/210 hydraulic roller cam kit
Camshaft
Cam button
Roller lifters
Roll master double roller chain
Pushrods
$500.00
Front mount intercooler 3 inch inlet/outlet. I don't have the charge pipes
$300.00
Stewart Warner 160 speedo & 7000 tach
$200.00
Complete used set of gn badges driver shape $75.00
Stock driveshaft
$50.00
Precision TE 60 series turbo as is. Worked good but there is play between the cold and hot side. Turbine spins fine. Make offer.
109 turbo block
ARP main studs
rjc girdle
rjc crank scraper
20 bolt oil pan
$1,500.00
Camshaft
Cam button
Roller lifters
Pushrods
$500.00
$300.00
$200.00
Stock driveshaft
$50.00
