What's the trick to installing the GN 1 Performance extreme radiator? Mine is hitting the middle top tab of the core support and the top trans cooler fitting is hitting the A/C condenser. I can cut the tab on the core support but the fitting hitting the condenser will still not let it go far enough forward for the top plate to bolt up. Now, for you guys that are thinking about buying this radiator, PAY VERY CLOSE ATTENTION TO THE SIZE OF THE ENGINE OIL COOLER HOLES!!! IT COMES WITH HOLES THAT ARE LESS THAN 1/4''. THE FACTORY HOLES ARE A LITTLE OVER 3/8", THIS WILL STARVE THE ENGINE OF OIL!!!!! Needless to say, I'm not impressed with this radiator, especially after shelling out close to $900 for this piece! I also purchased their front mount intercooler and had to cut the center brace that goes from the core support to the grill. Why should this be acceptable to cut on our cars just to make aftermarket parts fit?
