For Sale
-GN-1s ported/polished, 1st Generation, the outer bolt holes under VC have been welded. On one head there still exists a slight pin hole leak/coolant, the other head is fine. The bolt holes have been enlarged to accept 1/2 studs/bolts. Double springs for roller hydraulic cam/ don't have spring specs on hand. Head surface has been milled recently.
Cheap $500 plus shipping.
-Set of GN-1 1.65 ratio roller rockers, shaft mount, rocker have been back cut slightly to use with 1.55 diameter spring. Had these rocker prior to emergence of B-hive spring. Good condition
$300.00 plus shipping
Thank you
If these don't sell here, I am going to put them on E-bay in 2 weeks. Giving the Buick community first chance.
Shipping costs figure from 07024
40lbs-pair of GN-1s
15lbs-set of rockers
Billy T.
gnxtc2@aol.com
Thank you
40lbs-pair of GN-1s
Billy T.
gnxtc2@aol.com
