GN tranny hunts between 2 and 3 under light throttle
Black3
Fargan sneaky bastages!
When I coast through my neighborhood about 20-25mph the tranny will sometimes get stuck not knowing if it wants 2nd or 3rd and will quickly jump back and forth shaking the car and making driveline clanks. All other operations are normal and TV is adjusted correctly. It didn't do this before installing CK tranny kit. WTF?
Do you have the dual feed mod on the direct clutch?
Tranny was 100% stock till I installed CK stage 1 kit recently, so I would say no. After installing the kit I immediately noticed that during normal driving the 2-3 shift happens right after the 1-2 shift.
I don't know why they do it but my CQ does it too, only sometimes. Have you tried moving the TV a couple clicks either way?
The kit does nothing to change the shift points,only the line pressure ,and clutch feed volume and pressure.Try tightening the cable 3 clicks and re roadtest.
