Good right taillight.
Flturbo6
Can some one give advise on relieving the pressure on Power Master unit. Initial is out of car
Usually you press the brake pedal ten or more times to get the pressure out. I would use a dowel or screw driver to push where the rod pushes to get the unit to apply. Do it ten it times and you should be good. Similar to bench bleeding a regular mc.
Thanks, I will give it a try
