I finally got the car running pretty good after the turbo, downpipe, valve spring, fuel pump install. In the last few days the car has done some strange things. When I go wide open throttle I get kind of a hiccup at about 16# of boost, that's what I have the wastegate set at. It just seems like everything stops for a split second, and of coarse I get out of the thottle. The check engine light flashs just once when it hiccups and then goes out, and I don't show a code in direct scan. A couple of days before this it threw a code 42 a couple of times, but then it went away. When it was doing this it was running fine though. I'm not sure what's going on. Any help? I'm showing no knock either.
