turbojitsu85
- Aug 23, 2002
The car is running fine now that I put the new fp in and figured out that my boost gauge was lying to me. I cleaned and balanced the injectors and and had my mechanic fix what was causing the problem with the boost gauge. The question I have is when I lay on the pedal hard the boost gets to about 9 or 10 PSI then when I hit third gear i will shoot to about 13 or 14 PSI. Is this normal I thought that it should run the same amout of boost thru all of the gears?
