all rplies greatly appreciated ..my buddy has a 95 1st generation lightning pumping 500hp on pump fuel.. we decided to run a little better than a 1/4 just to see what the gn would do.. believ it or not on take off he left me by a car length but when i left the line once thr turbo kiks in it starts spinning ..if i floor it from a stand still right when the turbo kiks in it starts breaking traction before it goes to 2nd then of course it breaks'em loose going into 2nd gear ..even tried power breaking it and launching with my boost gauge at 0 right before it begins to boost and its even worst ..it now has 235/60/R15's
im wondering would a 275/60/R15 fit on the stock wheels and clear the fender welds when turning or 255/60/R15.. just to keep traction etter .. also going to remove the stock gas shocks.and replace them with monroe load levelr shocks.. its a heavy duty gas shock with the heavy duty spring wraped a round the shock..suppose to be good for towing a boat or hauling a mild load so i believe wit those being stiffer it might plant the wheels to the ground better what do u fellas think
