Gta Rim Question
Turbodan
Does anyone have the GTA rims on their car with the 1" lowered suspension?
I have the lowered Eibach springs on my car. I am wondering if the GTA rims will fit under the lip.
Depends on the tires, of course. In back you shouldn't have a problem anywhere. It may rub the frame durring hard cornering with 255's, but otherwise no issues.
In front, you may get a little rub on the inner fender panel and you may have to remove a couple of the screws with 245's, but they should work. Aftermarket 12 " brakes may cause a little more of this rub.
I never had a problem with the rear rubbing. The fronts only rubbed the inner fender at full lock. BFG Comps, 255/50 rear, 245/50 front.
John
6APPEAL said:
The fronts only rubbed the inner fender at full lock. BFG Comps, 255/50 rear, 245/50 front. John
Yep, I'll confirm that. However must also take it easy with drainage dips in road, driveway entrances, etc., especially if have a passenger as wheels will rub kinda hard on inside lip of wheel well. Remove one or two of the small screws up on top inside of wheel wheel. Nice ride & stance though.....Ray
