Nov 4, 2007 #1 O orangecar Member Joined Nov 17, 2006 Messages 149 Will the GTA wheels that look like the GNX wheel fix on a GN properly if all four wheels are the GTA fronts. Thanks
Nov 4, 2007 #2 P phillyturbosix Moderator Staff member Joined Aug 24, 2003 Messages 4,285 Yes. You can use rear GTA rims but you have to run a spacer. Then you wind up with a shorter wheel stud and that can lead into some major issues! Run 4 fronts and you don't have anything to worry about!
