Guys running Pro star rims
GBGN1
BP Performance Transmissions LLC
I just picked up my new pro-stars and noticed the wheel studs dont come out that far-Is everyone getting longer wheel studs and open nuts or can I use the closed wheel nuts with longer studs-what to run at track so I need to know
thanks!
brian:D
Not sure if this is what you are looking for...
I have always just used the longer closed nuts that extend into the rim. I still run the stock wheel studs front and back.
I have never teched in below 12.0 though. Maybe the rules change at 11.99 - don't know.
I've got longer studs and longer nuts. I think you need the longer studs depending on how fast you are.
wellll once ya get your lugs squared away make sure ya check the rims every now an then for cracks ....I have 4 hose reels!!
