Broke down my engine to swap cams and noticed the harmonic balance doesnt fit snug on the crank/keyway. You can move it side to side pretty good. I checked another block that I had sitting aside which didnt have this problem, fit snug. After comparing, it seems that my keyway and the notch on my harmonic balance are both worn.
Im thinking that once everything is together and bolted tight it shouldnt move around (maybe). So Question is how big of a deal is this? Should I be worried about this now, and change keyway and harmonic balance?
P.S. keyway is not worn where lower timing chain gear is, just in front of it.
