NY Twin Turbo
All the good stuff.....Times 2.
- Dec 10, 2014
I have Cal's XFI 2 step ignition adapter for our factory ignition system. If I hot wire the ignition will it bypass the 2 step? Meaning, will it render it useless?
I was thinking. If I run a relayed hot wire to the ignition, and use a fuse holder in that line, then all I have to do is plug the ignition adapter into the new fuse. No?
Also, what wire off the coil plug is the one that gets the hot wire? I think there is 2 from my memory. One is pink and the other is pink and black?
