Head Gasket Upper Engine Set?
gn86randy
No can......can
Hello All,
Anyone know where I can get one locally. Thanks .........Randy
I believe that Fel-pro makes a head gasket set (includes everything needed when replacing heads except bolts). Dont remember the cost though but, Checker Auto should have 'em.
Good Luck,
Derek:cool:
If not you could peice it together. If your using ported heads than you should buy the fel-pro 1200 intake gaskets (from Rons) because they have bigger port openings. (they're $30 and are not available in any head set)
Thanks Derek
I appreciate the info, also was wondering about injectors the car has Bosch 36lb injectors and a PTE 51 turbo is that enough injector for the 51, seems a little small........
Hey Geoff
How ya been? have'nt seen ya since b4 Vegas, I am shooting to have the car completed by the 4th of DEC hope it all works out though, My brother will be here on the 4th its a Saturday would like to get a few fast buicks down to the Track that night I know it will probably be a pro gas night but who cares right.......well I been hen pecking these keys enough I guess so I will end here.....I was also wondering if its possible to get a max effort chip burned for my current setup 51/bosch36lb/ported steel heads
if not I could always put on the turbo chip and injector that I got from John.....I recon.......
minimum 42.5 injectors
What about the 50lb one I already have will they work ok?
Re: minimum 42.5 injectors
I would use the 50s with the 51. But that's just me.;)
I got them
But what about the max eff chip that came with them and the 63 Turbo will it work with the 51 and the injectors vice the 63.....thanks for assist
Probably best to e-mail Steve about that. I woould guess that with some tuning, you could get it to work. If he sends me the file, I can burn it. :cool:
