hey guys.. i just bought a set of those 'diamond cut' h4656 headlight housings ..
anyway the kit, for $50, comes with:
2 glass housings
2 55/60w bulbs
2 peanut lights that go inside the housing too.
and 2 wiring adapters, because i guess the H4 bulbs are wired different than the sealed beam bulbs.
So anyways, my problem...
the high beam light inside the car never goes off. it is either on dimly, or on brightly, and the inside two headlights stay on either way, i figured this could probably overheat my wiring, so i just unplugged them for now to be safe.
if anyone can tell me how the stock headlight plugs are wired, like out of the 3 prong connector, i believe there are 2 beige wires, one black, and one green.
now what SEEMS to be going on when the high beams are left plugged in, is that on the new bulbs, the low beam and the high beam filiments light up, not just one or the other.
anyone know what to tell me? thanks guys, im about to go outside with a volt meter and try figure some stuff out.
if anyone has gone through this before, let me know! thanks guys!
2 glass housings
2 55/60w bulbs
