Heads Ported to Powersource specs
BadAssGN
Certifiable Member
I had the oppertunity to view and photograph a set of heads that were ported by an experianced local guy that has ported many buick heads with excellant results.
A picture is worth a thousand words,
those of you with the buick powersource book turn to pages 65 and 66
The two templates you see are what were used and are a perfect fit in these heads.
These are not my heads ( I wish they were) if serious buyers pm me I will put you in contact with the man that did the port job.
I should also mention there is the option to finish these heads to suit your needs and preferances.
There are pics posted here http://www.turbobuicks.com/forums/showthread.php?t=53698
49-blues said:
how much to get the port work done?
The guy that did the port job owns the heads, I understand he has over 50 hours of work in these heads.
They look great huh....
The man that does this work is retired and a huge buick enthuseist.
he does maybe 2 sets of heads per year and the lucky few to get them are very happy. your best bet is to buy these rather than send your heads to him. turbo heads are not hard to find. if it's stage 2 heads you want done pm me and I'll give you his contact number
not many can take full advantage of a set of heads like this.
I can do you a set of iron heads plus intake for 1100.00 That includes a full race port job with radius valve jobs with bigger ferrea valves, .531 teflon seals, rockers clearenced for roller rockers and bigger lift cam your choice of springs ie. roller or beehive with 10 degree locks and retainers. these heads out flow champions . I have done many sets for different board members some running in the 9.s Intake will be fully ported with option of welded egr or not. Previous heads can be viewd on ncturbo's slowgray link.
