Heat Shield Template
heat shield
I had to trial and error mine, more error than anything else.
Also shield had to be shifted to the exhaust side a little. Finally got it mounted by shifting the shield over one bolt hole.Now one bolt on the front and one on the rear hold the shield on with a nut and bolt in the empty holes for show.
Shield fits like factory, can't even tell the difference other than the uneven edge. Now I'm looking for a plain crome shield to cut right this time and use the error shield as a basis for my template.
The oil feed line causes the problems lining the shield.
Try making a cardboard copy of your shield and cut that.
HTH
1.81
1.81 sec 60' running 21 psi boost, BFG 235/60 drag radials, 4 psi launch.
To everyone on this discussion
Want to thank everyone who paticipated in this dicussion.I have had a turbo buick. Well 4 or five of them since 92.
And I have to tell you. Not by names but as a collaberation. That I have learned more. Then I could ever remeber.
Thanks to everyone.who explained,gave numbers. But most of all taught.
This was a real treat. My signature,I took off because. I was always trying to make things better. You gave me more information to begin than you could imagine.
Thanks to all..............................Rob :o
cool
:cool: Every day is a day I can learn more, only a fool knows everything.
I too learn from the members on this site. Thanks all :biggrin:
