heated o2 sensors
trbojo
'Stang Stinger
i just ordered the heated o2 sensor kit from casper's. anybody using one or something similiar? how do they hold up with leaded fuel?
Mine lasted for about couple years. I went and bought a Denso O2 sensor. They are alot cheaper and from what i understand they last for a while to.
I'm running a Casper's heated O2 setup. Can't remember exactly how long I've had it in the car, but I've probably run about 25 gallons of leaded thru it over the past 2 years and it's still working fine.
If you're asking me...the answer is no.
Mike
P.S. It's not nice to hijack someone else's thread.:D
2 years isn't bad. you can get replacement sensors for i think 59.00 which is about what the denso's go for. how are they as far as switching and warm up? alot faster than the single wires?
Useing Caspers heated 02 with no problems.The only problem with heated 02s is that when they go bad sometimes they will not trip a code.
