May 27, 2004 #1 L lazaris Active Member Joined May 25, 2001 Messages 1,497 Anyone running these or have experience with them?
May 28, 2004 #2 L Larry New Member Joined May 27, 2001 Messages 336 My block from T/A is on the way so I can not comment on there performance, but- Mike did use those in my Motor. You may contact his shop. Larry
May 28, 2004 #4 1 10SV6 New Member Joined May 28, 2001 Messages 251 Are the Hellfires a tool steel ring ?
May 29, 2004 #5 S StageII86 Member Joined Mar 4, 2002 Messages 458 I had hellfire tops in my old on-center motor w/ C&A 2nds and oil. They sealed up awesome and were tough as nails. Always <4% leakdown on a cold motor.
May 30, 2004 #6 L lazaris Active Member Joined May 25, 2001 Messages 1,497 I believe they are not tool steel.
Jun 10, 2004 #7 L laz Tso Racing 2010 Joined May 23, 2001 Messages 523 The problem is with us 3.8 guys is they only start at 4.00 bore . I run them on my nitrous smallblock . Laz
Jun 16, 2004 #8 L lazaris Active Member Joined May 25, 2001 Messages 1,497 I found out they dont make the Hellfire for a 4.00" bore with a 1/16" ring...............
