turbofoot1
- Oct 20, 2008
Thought my master cylinder was bad cuz it was sticking at the top, so I replaced it with a known good used one off my other 86 t-type. Now, When I turn on my key, I hear the powermaster start running and my brake pedal begins slowly moving to the floor by itself. When the powermaster finally shuts off, the pedal remains on the floor and the brakes are fully applied. NO foot assist at all. All automatically performed by the Powermaster, obviously. I have tried 3 pressure switches and ohm'd each one open and closed, they are fine. The brakes work normally in unassisted (disconnsected PM) mode, which leads me to believe master cylinder is fine. I have tried 3 accumulators off same car, no difference. I have swapped all my parts around every combination and end up with the same results. PM still applies brakes when key is on and car won't move. I am a mechanic by trade and at 50 thought I was pretty decent at diagnostics but have fooled myself again. Any help would be greatly appreciated. Rusty
