Help Chris !!
wahoo50
My 200R4 was flair shifting on the 2-3 shift. I have installed your valve body kit (easy installation by the way) but I still have the flair shift. Can you suggest anything else I can do to stop this?
Flair shift
Where do I purchase a pressure guage and where is it connected? What should the correct pressure throughout the shift be? Thanks Chris.
2-3 Flair
Pressure checks out as follows;
1000RPM Idle, trans cold
...........Min TV.......Max TV
Park.....65.............85
Rev......110...........245
Neut....65.............200
D4......65..............205-240 fluctuating
D3......69..............205-240 "
D2......200............205
D1......200............205
1000RPM Idle, trans hot
Park.....52............50
Rev......110..........105
Neut....67............155-165 eratic
D4.......67............135
D3.......67............125
D2.......125..........125
D1.......120..........129
Light throttle:
2-3 .......100-->115 during shift-->115 after shift
Med throttle:
2-3........155-->155 during shift-->155 after shift
WOT:
2-3........160-->160 during shift-->160 after shift
Cruising at 2000 rpm 4th gear: 100PSI
Cruising at 2600 rpm 4th gear: 95PSI
All is well except the 2-3 flair shift. Suggestions?
the pressure reading look wrong.please take them over again at 100o rpms 0 tv and 1000 rpms full tv.
after verifying the oil level is correct use the manual and inspect the throttle valve in the valve body ,the tv limit valve ,the line bias valve,and then the tv boost valve and pr systen in the pump as well as the filter.
