help find test connector
I beleive it is the grey wire, 'shemale' fitting that comes out the front of the wire loom on the left side, front of valve cover,behind alt. can't remember if you ground it or 12+ to it.
Sure someone will chime. Try grounding first, if no worky, hit it with 12+.
This is also were you plug in to manaully drain the fuel tank
It's a black female connector located behind the alternator. You apply +12v to it to activate the pump.
