TurboTA3.8
You wont keep up the pace
- May 24, 2001
well finaly my car is up to snuff and i get it on the dyno to do some tuning tonight just got a dynojet 224x thing is great
so anyway the first pull it breaks up so i change the plugs and gap them to .028 then do a pull it pulls great to 5800 then like noses over and breaks up the a/f went a little lean 12.6 but not enought to have the power nose over that bad this is at 10 psi boost coil pack and module are new and plugs are new and the wires are in great shape it happens at the same rpm i tryed it at 3 boost levels 10,15,20 same spot each time the springs are good big k motions head gaskets are good and it passed a 8 % leak down any one have any ideas is the stock ignition not up to par what are people with my setup using.
thanks
george
thank god 4 year project coming to a end
well it made 540 at 15 psi at 5600
thanks
george
