I'm trying to install wilwood rear disk brakes. The bracket for the caliper goes between the C clip eliminators and the axle flange this leaves just 4 bolts to hold the axle and C clip eliminators that contain the bearing.
Is this right?
Without the brackets, the axle housing extends threw the axle flange by a 1/4 inch and goes inside the C clip eliminators and 4 bolts hole it tight to the flange.
Is this right?
