Anthony P
sharing knowledge with those who care to listen
- Jan 24, 2007
using the C3I ignition simulator on GM + aftermarket coilpaks attached to GM ignition modules -
When at full RPM simulation (8000), some of the electrical arcs for the individual coils form a multiple-stranded arc rather than a single arc between the washers. Please refer to attached pics. I'm testing multiple coilpaks (used and new - ACDelco and SMP DR36 versions).
The multiple-strand arc occurs at top-end simulation, when the audible frequency changes to the highest pitch. Also, with these multiple-strand arcs, there is audible "static" at a lower frequency that can be heard.
The multi-strand arcs can occur on both new and old coilpaks, regardless of brand. FWIW, the applications are for stock or near stock GN's producing maybe a max of 16-17 psig boost via a turbotweak street chip.
What is the electrical terminology to explain what is happening here?
Is the formation of a multiple-stranded arc an indication that respective coil is experiencing a breakdown?
And that while that coil still fires, the multiple-stranded arc is illustrative of a weaker electrical field and cooler spark that could become problematic under boost?
