Tori
- Nov 4, 2013
I don't even know where to start.... My car has been sitting for the past 1.5 years. And normally getting it to pass smog isn't too big a deal. I do the same thing every tow years and it'll pass. Install the cat, hide the translator, install the emissions chip and adjust the fuel pressure.
This time when i do this, it idles fine but the 2500 rpm range it starts cutting out runs like shit.
Exhaust will bring tears to your eyes.
The TT emissions chip says 38# fuel pressure, - is that with the vac. line on or off ? This was also the same chip i used with my stock 30# injectors, now with 42# injectors, does that have an impact ? Turbo Tweak says no.
I've tried adjusting fuel pressure up and down at the 2500 rpm range and it has little to no effect.
With the TT emission chip, do i need to move the Translator Base switch to 5 ? (10% lean at idle). - isn't the chip doing that ? I've passed in the past without adjusting the Translator.
Anyone care to offer advise ?
