First of all let me tell you that I have manual windows. My biggest problem is that the drivers side window seems like it needs to be pushed in more. There is a plastic tab on the A-pillar that interferes when I try to close the door with the window all the way up. I hear this is a common problem on Regals so I'd like to know what I should do to fix this.
Also, I'm trying to stop a T-top leak. All the seals are new, but it will leak inside of the car near the top of the driver's side A-Pillar. Any suggestions?
Thanks,
James
Thanks,
James
