Scott Atk
Senior Member
- May 25, 2001
Well it happened again at the track last night. Time to turn to my brothers for help.
I have an intermittent electrical problem that only rears it ugly head at WOT. I can drive the car on the street at part throttle all day and it will never happen. Here goes...
The car will be pulling great and then just fall on its face almost as if its shutting off for a second then pick right back up. Sometimes it will do it three times within a quarter mile sometimes once, sometimes not at all (rare). When I playback TLink I get all kinds of crazy data for one frame corresponding with the stumble. Stuff like TPS goes to 2.xx when I never lift, battery volts go to 6.xx, P/N switch turns on, MAT goes to 47 degrees, then everything is back to normal for the next frame. Here's what I've checked so far. Battery cable to starter is good, grounds at back of head are good, ECM has been swapped. I really feel like its a ground problem but not sure where else to check. Im running the MAX EFFORT 16 pos. chip, 55 lbs injectors, PT54 turbo, PTE front mount, vigilante "0" pump, anything else that anyone thinks might be pertinent just ask.
Thanks !!
Thanks !!
