When I step on the gas the car has a bad hesitation. It idles really low, and sometimes irratic. When the car is cold it usually run great,, The hessitation is almost not noticed. Now when cold its acting up as well. It feels like there is a miss off idle, but now when at a cruising speed. Every now and then if im idleing in gear and I hit the gas a little( spike it really quick) the car feels like its gonna die or now and then will die out. It will start right back up. The last couple days when I start t when its cold it dies out right away,, then it restarts and stays running. I just rebuilt the motor and before I was having this problem,,, and now its happening again. The car also feels verysluggish. After the rebuild it was fine for a while then it started acting up again. There are no codes. I replaced the tps once and it ran the same,, and it is set. Cam sensor is new and set. The car also boosts very fast,, It seems like it is overboosting to 18psi right away when i give about 1/2 to 3/4 throttle. I was thinking the mass airflow sensor.. The car sucks alot of air when cold once warmed up it isnt that noticable. PLEASE HELP!!!!
