turns out I do have another question
I installed the kit and the new spring on my gov. Part throttle shifting is excellent. 1-2 is very firm. But now that I have some WOT runs in, there is an issue. 1-2 seems to be pretty good, about as good as I can expect I suppose. Its better than before. Now, 2-3, it gets up to about 5500 which is where it shifts 1-2 and then it feels like it either jumps out of gear or slips, then over revs the engine to about 6k and then eventually hits 3rd.
I initially tried loosening the TV cable some which didnt help and now i realize that it wouldnt judging by the symptoms. Any ideas?
Just as a recap, The car shifted fine at WOT before I did whatever it was that caused it to have the same symptoms as a thrown gov. spring. When I tore it apart i found the gov spring was still on there (only one spring) so i just swapped out the spring with then new one you sent. I also installed the shift kit figuring what the hell, couldnt hurt while i was down there.
I probably threw in too many variables into the equation didn't I
