High Speed Fan
gn86randy
No can......can
I bought a new HI Speed fan relay for the A/C but still doesnt work any one have any other suggestions........Thanks in advance for the assist............Randy
did you replace the delay (big) relay or the acutual "high" speed relay?
There are three relays on the drivers fender, the big one is the fan delay relay and the other two are seperate low and high speed relays.
Do you have the stock fan? If you do than the resistor might be no good but that's for low speed.
Its the FAN inside the car for HEAT/ AC
I replaced Relay on passenger side screwed in firewall behind accumulator #10018449 that is what the guy told me was the high speed a/c fan relay but somehow I think he was mistaken....I have'nt checked the relays on the drivers side, and no its NOT a stocker fan its the dual fan........thanks Randy
What it looks like is you need the pin to insert to the fan hardness to have the fan operate with the A/C on
Did you check the ground wire on the fan.
I will have too check that
I am at work now so maybe on Monday When I am off I will check out the ground wire also the Damn Power Antenna won't go down Either prolly will switch good one from my 86......Randy
