Hot air conversion
ratchet45
Does anyone have info on a cold air conversion kit for an 84 T-type? I hear there is one from Spearco.
Not sure if this would work but...
..a freind of mine has a TA49, a stock IC with a Duttweiler neck installed, all of the pieces that go with it (shroud, IC fan, etc.), a set of 43 lb injectors, the chip to go with it, and he's asking 750 for all of it. The turbo has about 2000 miles on it. He upgraded to a PTE61, a Precision FMIC, 50lb inj., and a new chip. I really don't know what all else you would need. Maybe someone else who knows will chime in. :cool:
I'm going to be using the turbomotion V2, I'm told it's better than the spearco kit,allthough I've never used either. In a week or so I'll be able to let you know how it works. :D :D :D
Or you could swap over to 86-87 status ie more and better parts availability IMO. I do like a fast hot airs cause they are rare indeed. Ive decided to keep my t type a hot air when I swap the sbc.:)
