I Need to clean out the garage everything is in good condition unless noted and I can send pics of anything you need. also everything is stock and off an 84 WH1 with 100k on it.
Stock MAF Sensor
Stock Downpipe
Stock Cat (This thing is toast its only worth gutting it if you ask me)
Stock Headers (Cracked on Driver side not bad though)
Stock Crossover pipe
Stock Fuel Rail
Stock injectors (Unknown condition)
Stock injectors (Cleaned and Flow matched)
Stock ECM
Stock Motor Mounts
Stock Air Cleaner setup
Stock Fuel Pump
Stock Knock Sensor
(2) Stock FP Regulators
Stock Injector Harness (Some cracking but worked fine when I had it on car)
Stock Wastegate
Stock MAP Sensor
Downpipe Heat Shield (The Postons one that clamps to the DP)
Complete AC Setup (Evaporator, Condensor, Compressor, all lines)
R44ts spark plugs
I know Some of this stuff probably isn't worth much but if it helps another buick owner out... I'm open to all offers and possibly trades. like I said I Really need some extra space in the shop... and money for a TA33
Stock MAF Sensor
Stock Downpipe
Stock Fuel Rail
Stock ECM
Stock Motor Mounts
Stock Fuel Pump
Stock Knock Sensor
Stock Wastegate
Stock MAP Sensor
R44ts spark plugs
