hot air throttle body question
boosted84
can the hot air throttle body be used in the piping with an intercooler without any mods done to it including the vacum pod on top and iac
my plans are to put it in line right before it turns in the intake just dont know if any thing has to be changed thank you
ANTHONY
my plans are to put it in line right before it turns in the intake just dont know if any thing has to be changed .....
Don't think the HA TB is designed for boost applications and there have been problems. It is designed for vac. Better use the TB of an IC car.
Mine works fine under boost with no mods. You'll need to put check valves in some of the vacuum lines 87 style.
ok what do you need the check valve for can you explain it a little better cool 84 thanks anthony
The ones you don't want boost getting into. Off the top of my head would be the vapor line from the charcoal cannister, cruise control, vacuum cannister. That's all I can think of now. I only have one vacuum line off the TB so it's a little hard to remember what originally went there.
