Some one must have run in to this before but what does it take to use the 84 TPS with the 87 ECM? I can't be the first that has run into this? I know wiring is different on two of the terminals but what is the work around. Th
I did nothing other than mod's - Caspers 84/85 CCCI Hotwire Special to use the 87 CCCI MODULE and COIL and it works fine but ....... I believe you also are using a 86/87 wiring harness. Am I correct in my assumption?
