b4black
- May 24, 2001
95% sure it will work. This is an '85 uppipe on an '82 turbo V6. I assumed they wouldn't fit becuase the hot air turbo inlet points a little downward and I thought they used a different connection. But they are the same and it bolts up. This motor is not running and I didn't tighten down any of the bolts. Only place I see a potential issue is the downpipe and uppipe are very close.
I also don't know if there is any advanatge to the Hot Air uppipe. Some people cliam is is a bigger diameter - but I can't tell with the braids on it. Bigger might not be better anyway. The pipe will be going on another car soon, so I won't get to try it at the track.
Something to consider if you come accross one cheap at a swap meet.
