Hot ign circut while cranking?
fuzzyGN
Does anyone know of an ignition circut that remains hot while cranking? Most of the ign circuts cut out while trying to start the car. I have an a device that need ign hot but once keyed up it needs to stay hot. Any ideas of where to look? Thanks
FP/INJ, ECM/IGN, ECM/SOL, CCCI, GAGES, according to the manual IGN 1 on the STBLT/ACC fuse is also hot in start.
Might be too low a voltage while cranking to keep whatever running you need to run, probably down to 8 volts on the battery while cranking use a meter to test it out. And check how many volts you need to keep the device running whilst cranking.
