Nov 15, 2005 #1 S Sweet6 Well-Known Member Joined Jun 12, 2001 Messages 3,535 My car is acting strange and I think the TCC solenoid may be bad. How do I check it? i am assuming disconnect it? Any help is appreciated.
Nov 15, 2005 #2 8 87 Pete Member Joined May 25, 2001 Messages 320 Sweet6 said: My car is acting strange and I think the TCC solenoid may be bad. How do I check it? i am assuming disconnect it? Any help is appreciated. Click to expand... My transmission was acting flawlessly, then one day it started bucking a lot. It also did not want to unlock when I came to a stop, which makes the car jerk as you come to a stop. Cruising above 45 mph was fine though. Pete
Nov 15, 2005 #3 S Sweet6 Well-Known Member Joined Jun 12, 2001 Messages 3,535 Did you notice your RPMs skyrocketing when you took the car out of gear? Also did you have problems getting the car in gear?
Nov 15, 2005 #4 8 87 Pete Member Joined May 25, 2001 Messages 320 Sweet6 said: Did you notice your RPMs skyrocketing when you took the car out of gear? Also did you have problems getting the car in gear? Click to expand... In my case, no I did not have those symptoms. Pete
