I am think about getting a Grand National or a t-type an I would like to know if I get this suff will I be in the 11's
*Turbonetics stage 5 turbo
*3" Houston down pipe SS
*Flowmaster dual exhaust
*3" Catalytic converter
*3" Mass air flow pipe chrome
*ESP remote fuel pressure regulator
*ESP stage 4 cam/lifters
*New valve springs
*Corvette LS1 3 1/2" mass air flow sensor
*Translator spark & fuel controls
*ESP cutom thumbwheel chip 8 programs
*009 injectors 43 lb
*ESP high output coil pack
*10mm ignition wires
*2" dropped front spindles
*2" shorter rear springs
*Boost controller
*Scanmaster
*Boost gauge
*New timing chain w steel gears
*K&N air filter
*Fresh air intake system
*Art Carr 9" 2800 RPM stall non-lockup
*Art Carr shift kit
*Fuel pressure gage in line
*Plenum spacer
*Misc. chrome under hood
*Disc brake dust covers;front
*Complete 3" exhaust system
*Spare turbocharger
*All stock omponents remove, converter, springs, injectors, mass air flow, air filters
*Kenne Bell oversize intercooler neck
*Optional grounding kit
*3" converter dump tube
*Dynotech stage 4B chip
*ESP street lethal chip
*Fuel pump hot wire kit
*New valve springs
*Boost controller
*Scanmaster
*Boost gauge
*K&N air filter
*Art Carr shift kit
*Plenum spacer
*Spare turbocharger
