SignUp Now!Originally posted by fireberd350
Zaino is more hype than anything, especially on these forums...but yes Zaino is a good product when used correctly. Nobody can deny it's wet look and extreme durability. I'm am an ex Zaino user, but have moved onto different products and have had amazing results.
The biggest problem with Zaino is that there is no swirl remover in thier product line. I know people are going to claim Z5 is a swirl remover but I won't even argue with you b/c I know for certain it will not remove swirls (it hides them at best, and does a poor job at that). You will need a good polish and rotary tool to get the swirls out, that goes without saying. Black is the hardest color to care for, and it will look like crap no matter how many coats of Zaino it has if there are swirls all over it.
Basically it all comes down to the prep, prep is EVERYTHING....the products you use are almost a non-factor after you consider the prep and process. Zaino is a good product when it has a good prep under it, does it live up to it's miracle working hype - NO....can I recommend it to you - sure.
I'd suggest going to http://www.autopia-carcare.com/ and reading everything on there before making your decision.
Good Luck!
Originally posted by Red Regal T
I'm currently using Eagle one NANOWAX. Works pretty good, but I thing the secret is, as ZAM70 has expressed many times, is not to use cotton cloths to take off the wax. You have to purchase the micro fiber cloths. They leave no fine scratches as with cotton. In themselves, the micro fiber cloths make a great improvement.![]()
